Bolero preout lead?
I've done a fair bit of searching on here and couldn't really find an answer to this, so forgive me if I'm asking something already answered...
I currently have a 07 Fabia vRS SE with standard Skoda Head Unit, which has one of these adaptors connected to the back of it:
http://www.bluespot.co.uk/car-audio.aspx/7607893093-adaptor
Which gives me the preouts to connect it to the Blaupunkt THB200A Active subwoofer under my seat:
http://www.bluespot.co.uk/car-audio.aspx/thb200a-speaker
It does a good enough job for me of just improving things a bit over the standard setup.
Next month if all goes to plan I will be changing to a 170TDi Yeti Elegance which I understand has the Bolero head unit.
I would like to take the Subwoofer unit out of my Fabia and put it in the Yeti.
So on to my question - will the same preout adaptor that connects to my Fabia HU plug into the Bolero (doubtful, knowing my luck), or alternatively, can someone point me at what adaptor cable I need instead, and is it just a simple plug in job again like it is with the Fabia?
I've found the threads on here about how to actually remove the Bolero to hopefully plug in whatever is needed, just would like to know what I actually need to buy assuming its not the same connections as the Fabia.
Many thanks in advance for any help and guidance.
Cheers,
Simon.
