How do I change MK2 Octavia VRS Front Foglights?
Hi, One of my front foglights has failed and I'm having problems accessing the filament. I've managed to remove the outer basel, which uncovers one torx screw. Do I simpley undo it and pull the foglight assembly out? Any help would be much appreciated, thank you.
Sorry-it's not that easy! :( That Torx screw is only for adjustment-you need to access the bulb from behind-drop the front section of the drip tray (Torx bolts) & you can then see the covers on the back of the units-they twist off & then replace bulbs (H1). Some say take the bumper off (which is ideal, but time consuming)-I've managed to do it with a little automotive gynaecology & a torch!!! :giggle: A jack/ramp/lift/axle stand is useful too! :thumbup:
Thanks, I'll give it a go tomorrow providing the lovely UK weather holds out!! :smirk:
Manged to do it by popping out the front headlight in the end which was a bonus! :yes:
