charcoal cannister
can anyone help there is a strange beeping noise coming from engine bay,i traced it to the charcoal canister,it appears to be coming from the white breather pipe which comes from the fuel tank,does anyone have any idea what the cause could be,thanx in advance for any help B)
It will be the purge valve in the top of the canister.
If you want to try cleaning it...
Remove the fuel filler cap (IMPORTANT)
Disconnect the plug and hoses.
Carefully prise the valve out.
Clean with IPA.
IIRC, a replacement is expensive so it's worth trying to clean it first
