Converting from 5 speed to 6 speed
HI, All i hope you can help, I have a Fabia TDI non Vrs which is 5 speed, Ive found a 6 speed gearbox from a chap brekaing a vrs and need to know exaclty what i need to convert mine to 6 speed,
Ive ask him for:
Gearbox
Both driveshafts
Shifter mech
Clutch/flywheel
Is there anything else i would need? Ie different engine mounts? pas lines?
I knwo my dogleg mount is different so ive got to get that from him too
Any help would be good as im supposed to be collecting it all tommorow and want to get everything from one place
Front subframe and n/s console if not with the subframe
Clutch pipe work
Starter motor
Mounting
is the subframe definalty different?
Yes it has a different shape as the diff is much bigger and fouls on the normal subframe.
ok thanks for your help
Oh and get all the bell housing bolts also, different lengths.
