Carbonio fitted but problems.....
Morning all! I fitted my carbonio to the vrs last night and have run into a slight problem. The hose connector supplied keeps popping off and is simply too short. So had a look at how Rob did his on pimpmyskoda and on the fitting guide it looks like he uses the connecter supplied, but then in other images a much longer blue samco hose has been put in its place which makes me think this original connector hose being too short is a common thing?!
what i want to know is the size of the maf. the carbon pipe work seems a lot larger in size than the oem maf it connects to. is it best to get a reducer - if so what size? whats everyone else's work around this problem?
any advice would be great :thumbup:
cheers
Was it bought new? if so ring the supplier and explain your issue and tell them to send you a better pipe.
Other than that there's plenty of samco type tubing on ebay etc.
Maf is 2.5" i think but not 100% sure
Dave
standard maf is 2.5 yes
cheers guys i will get a reducer off the net - sounds awesome now though, well chuffed with the results
I have to say if I had just spent 200 odd notes on an air filter for my car and it didn't fit I would be taking it back!
I extended mine with a couple of 2.5" silicone joiners and an alloy extender - but I also think I fitted it the wrong way around as it was easier to get past the headlight and battery that way.
I extended mine with a couple of 2.5" silicone joiners and an alloy extender - but I also think I fitted it the wrong way around as it was easier to get past teh headlight and battery that way.
its funny you say that rob because when i looked at it i thought i had fitted it the wrong way round. :giggle:
but all seems to be in place now and fits nicely. i phoned the supplier and they did say they had a few complaints about it popping off and being too short etc. they offered to take the system back from me but since ive fitted it i cant be arsed with the hassle so bought a reducer last night and for the sake of a tenner im gonna stick that on and that should sort it :thumbup:
Edited by vrs200bhp
Mine didn't pop off - it pulled the TIP off the turbo!
Which was a bit of a problem as I didn't know about it until I started getting a CEL, and by that time my MAF was busted :(
