heater fan
Hi All,
I have a 2000 Octavia Tdi SLX and it sounds as though the heater fan has started to pack up. A week or so ago I started to hear a rattle when I turned on the blower and I cannot adjust the speed. Currently it [the fan] either doesn't at all, it rattles or is intermittent. When it rattles there is a slight flow of air regardless of the speed setting. As winter is just around the corner I want to get this sorted as the car is having misting problems.
Any thoughts?
Neil.
A rattle sounds like an issue with the motor bearings I'm afraid.
If the switch starts to fail (not cars with push-button controls, eg Climatronic) it's usual for the low speed to go first, then the others from low to high in that order.
  • 4 weeks later...
Hi my blowers now only work on number four all the lower setting dont work, so am i right in thinking all i need is a new switch?
thanks
chris
thanks
chris
The switch will be OK. What you need is a new series resistor. It's a common fault.
Ah, I'm used to the resistor pack being part of the switch, or the switch contacts wearing out.
