Octavia TDI Help needed with Fault Codes
Hi all.
I need some help with some fault codes. My 2004 Octavia 1.9tdi pd (new shape) has pulled up 4 fault codes as follows:
P0674 - Cylinder 4 Glow plug circuit (Q13): Electrical Fault
P0322 - no idea
P0113 - no idea
Could someone please fill in the gaps for me. The car is struggling to start when cold.
Thanks in advance
Hi
I looked these up with my DTC Library (Download from Autel) I have NO IDEA what they mean but hope they may be of use to you.
P0674 : Glow Plug/Heater Cylinder 4
P0322 : Ignition/Distributor Engine Speed Input Circuit - No Signal
or Ignition/Distributor Engine Speed Input Circuit No Signal
P0113 : IAT Sensor - Temp Low - Circuit High - G42
or IAT Sensor - Temp Low - Circuit High - G42
or Intake Air Temperature Circuit High Input
If you look at Ross Tech they have a library and possible solutions. For example, P0113 is covered here: P0113 - P0674 here P0674 and P0322 p0322
Note there is a special forum here for codes.
Anyway, Hope this helps.
Edited by FriendlyFire
Hi
Thanks for the reply, sorry about posting the fault codes in this section, did'nt realise there was a dedicated area.
I have cleared all the fault codes and the only one that keeps coming back is the P0113 : IAT Sensor - Temp Low.
I want to go out and replace it but cant find it... I have heard it is somewhere on the filter box but the only one i can find is the mass air flow sensor :S
Please help
I want to go out and replace it but cant find it... I have heard it is somewhere on the filter box but the only one i can find is the mass air flow sensor emoticon-0124-worried.gif
Please help
Does anyone know what the part number for this IAT sensor is :S Just rang GSF for a replacement sensor and they had not idea what i was talking about
Just found out the IAT sensor (Intake Air Temperature) is NOT part of the MAF (Mass Air FLow) sensor but is infact intigrated into the Boost Pressure Sensor located on the air pipe bellow the glow plug harness. You need to take the engine cover off to see it.
I bought a new one (£45 inc vat) and the fault code no longer comes up.
Happy days :D
