Indicator fault
Hi Guys.
I have a y reg Octavia 1.6.
It has developed an intermittent fault with the indicators.
If you push the levedr up or down sometimes the indicators will work fine, but some times they will click and flash once ,or 3 times or not at all.
This is happening for both directions.
Any body got any ideas what is wrong?
Tony.
Hi Guys.
Tony.
Hi Tony
Do a search on here , but could be the hazzard warning switch
That is where the relay is you see ;)
Good luck
Good news is , not expensive and easy
Sarah
Hi Tony
Good luck
Sarah
Thanks Sarah.
Do you know if the actual hazard switch as shown in the link below ci the part needed?
Thanks.
Tony.
http://cgi.ebay.co.uk/Skoda-Octavia-Hazard-Warning-Light-Switch-relay-NEW-/400179500730?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5d2c8e96ba
Thanks Sarah.
Thanks.
Tony.
Hi
yes it does look like it
The switch is specific to the Octavia because of the dash
I must admit , I can remember when I was at Skoda parts I remember there was 2 to choose from , as one was slightly uprated for towing
But hey worth a try
Sarah
