PCD of wheels
Edited by Czech Bra Size
5x100
It is basically the bolt pattern - Not sure exactly what PCD stands for but probably circular diameter is the CD bit. It basically means if you draw a circle around the wheel, the diameter is the "100" bit and the 5 is the number of bolt holes. The line which the "100" is based on always goes exactly through the middle of the bolt holes. :)
It is basically the bolt pattern - Not sure exactly what PCD stands for but probably circular diameter is the CD bit. It basically means if you draw a circle around the wheel, the diameter is the "100" bit and the 5 is the number of bolt holes. The line which the "100" is based on always goes exactly through the middle of the bolt holes. emoticon-0100-smile.gif
Its means "Pitch Circle Diameter" and the hole centres are equi' spaced on the diameter unless otherwise specified.
Peter
