Which are the 2 wires to switch for memory wire? Also question about CD changer.
EDIT: Fixed it all :)
Had to swap around the yellow and red wires (they already had bulet connectors on luckily) and then found out that the sony ch changer i have needs an adapter to fit with my jvc headunit.
Will leave thread here for reference :thumbup:
Hi.
Had my fabia for a while now and had to swap the standard headunit for an aftermarket one since i didnt get told the code!
It all works fine apart from the memory.
I know this is the blue wire and when cleaning my air con fan out i found the blue wire...
The last owner had an after market headunit and sub etc so im guessing the wire i found was routed to the boot.
Im getting abit annoyed now of keeping going through setting everything so im wondering what do i have to do to get the memory to stay?
Cut and swap 2 wires?
Which 2?
Also, i have a cd changer from a while back, the last owner left the wires for his sub in my car so im wondering if they are the same used for a cd changer?
Thanks.
Craig.
Edited by Craig Lovelock
