Trunk inside cover
Can anyone tell me how the cover of trunk come of? It's the cover inside the trunk covering the lock. I took away 4 nuts, but still it is quite hard attached to trunk.
I have removed the trim covering the inside of the boot lid to free a stiff lock mechanism.
Remove the warning triangle and remove the trim screws. There are more screws in the "hand holds" if I remember correctly. The screws are hard to see as they have blackened heads. The trim is secured by clips along its outer edge - these are very stiff to remove. They also rust.
If your Superb is more than a couple of years old, the trim clips will be very rusty. Luckily, mine was young when I had to release them.
Grease all the clips carefully before replacing them.
rotodiesel.
Sorry. Actually I thought the lower cover, that covers the answer for lock. I want to see where the parking sensors wiring goes.
rotodiesel.
Is there any part of that poor car you haven't done an autopsy on yet Roto ?:giggle:
He probably trying to get it off so he can post how to remove it :giggle:
If I would actually get it off, then yes considering to write a how to :D. Actually I need to get it off, to get access to parking aid wires, going to bumper.
