amudson sat nav
Hi sorted out the satnav in the fabiaemoticon-0143-smirk.gifbit of a cuffuful but easy enough need a 4gb sd card so you can move the data from the cd and the cd is from bosch good stuff take about an hour to move onto sd card,you need to put the cd back in the unit once in a while as it does upgrade itself periodically,the sd card sit neatly in the satnav really good bit of kit and the rear parking sensors link to it awesome well worth the moneyemoticon-0148-yes.gifemoticon-0148-yes.gif
Hi there
perhaps you could help me
I am thinking of ordering an Amudson sat nav with my Fabia but I have been told it does not accept post codes
perhaps you could tell me if this is true.
Hi there
hi I am not sureemoticon-0136-giggle.gifgets the address very easy,brilliant bit of kit though Iwill check however and get back to you the reversing thingy is brillemoticon-0148-yes.gif
Hi there
Hi rag29,yes does postcode a bit differently to tom tom but it does do thememoticon-0148-yes.gif
Hisebon121
Thanks for your prompt reply
I downloaded the instruction booklet but I did not find it very clear
Glad you find it good to use
Hisebon121
Well here we go!,initially thought this was good sat nav unit but tried to put several addresses but it had other thoughtsemoticon-0114-dull.gif,its going to take time to get to terms with it,however today I used it on my travels and its amazing all the information thats given on the satnav is feeded into your maxi-dot display so it gives you pictures of your direction and images of roundabout ,slip roads, junctions and which road your on is elluminated on your dash readout on the maxi-dot computer just really cleveremoticon-0140-rofl.gif
