central
on my scenic the central locking locks the doors above 4mph
you may overide this setting if need be
it prooved its worth at lights
when someone tried the door handle wife only onboard
is this possible on the fabia se estate
thanks in advance
This can be set up using vcds
thanks in advance
This option can only be set by the dealer, do not forget to ask for the auto unlock as well. When the dealer did mine they did not set the car to unlock, got out of the car to fill up and doors were locked to get back in, stop and go to boot and it was locked - had to use fob to get in.
Now the car locks when driving, stays locked when stopped until the ignition is turned off then the doors unlock.
