Bluetooth a little bit tricky to navigate
I dont know if it's just me, but does anyone else feel the bluetooth menu and mediaplayer menu should have been able to be navigated with the roller on the wheel instead of the side stock. Or can you set it up for use with the roller?Opinions and help would be much appreciated . Cheers
I dont have bluetooth (Yet) but my A3 has 2 rollers either side of the wheel, and you use one to go through the phonebook, quite easy!
In the skoda you press the roller to enter then you have to use the side stock. Cheers
