Stereo wiring colour sodes
Hi,
I'm new to the forum & also to Skoda's. I need some help with installing a DVD head unit. The problem I have is identifing the correct wires in the cars Quadlock connector for the 12 v ignition feed & the illumination. I have the correct wiring adaptor harness. I have been able to get it working with a permenant 12v feed but not from the ignition. I also need to know which wire on the handbrake to connect the wire to allow the DVD to operate, I would imagine its the wire which become live when handbrake is on. The car is a 2006 Octavia 2.0 TDI Sport.
Can anyone help?
Hi and welcome aboard.
Welcome to Briskoda.
Not sure on your query, but sure some one will be able to help.
Davy
Hi,
Can anyone help?
I don't think there's an ignition feed behind the radio on that model. You'll have to go back to the fuse box.
No idea re the hand brake, but normally i think you just earth to make it work, so you can tie it to ground and have it work all the time.
Chers for your thoughts, will give it a try.
