Glovebox rattle ?
I had a rattle in the cabin somewhere around the glovebox about three years back and found the solution on here.
Recently. I had this occur again at around 1500rpm but could not remember the fix or find it on a search here.
My wife hunted around whilst I was driving but to no avail. Then I touched the handbrake accidentally and the noise disappeared - and my memory returned.
The handbrake button can vibrate and the noise seems to be coming from the glovebox or dashboard.
The fix is easy - just run some light oil or similar down and around the handbrake button. The oil acts as a damper fluid. I used some of the Quantum Q-Pro Maintenance Spray with PTFE that VAG and Skoda garages leave in the car after a full service.
If you have a rattle you can't find, check the handbrake push-button!
Mike
Thanks for the tip, i do have a glovebox rattle i haven't had a chance to look into
I'll have a look.
Mike
Yeah i found this with mine, all i did is put some silicon gease packed around it
I found a cure for all the rattles in my car, I turn the radio up until I can't hear them. :giggle:
After owning many Fords this is a solution I'm familiar with, lol
