no battery light but alternator is charging at 14 volts
hi please could someone give me some advise my fabia 1.4 tdi when i turn the ignition on there is no battery light but the alternator is charging at 14 volts
i have repaired the dfm wire the one that breaks at the gearbox bracket but to before that it used to work even tho one of the cables was broken i connected it up it colour for colour and it flickered on and off erratically and now it does not work ? any i dears ?
There are two signal wires connected to the alternator. The DFM wire and the D+ wire. It is the D+ wire that goes to the dash insert that is broken.
thanks for the reply it was the blue wire broken inside the connector at the alternator end i gave it a pull and i came out the back ill just have to use mini insulated spade connectors
