condesation
hy again
onther problem with my superb.After i drive 4-5 mile all the windows all cover in condesation.Does anyone know what the problem is?
Can it be from the air con ?
Edited by baubauro
And i also find that the carpet on the left hand side is wet
Bit more then just the use of the aircon, or lack of. Maybe a small leak from the front washer hoses - get it back to the dealers to resolve.
Do a search for 'water ingress' it is the most likely cause.
You have a leaking pollen filter seal. This forum is full of posts about this issue. Check that the front interior lights are working, they probably aren't or if they still are, then not for much longer.
i had a mecanic comming over to see the car and he said that it's probably from the air con because it's going to need regassing(air con it's not working).i don't know ,i'm going to try regassing the aircon in the weekend.i looked where the polen filter is and everything it's dry.the mechanic also looked for any water leeks but he could't find nothing.i just have to wait until sunday.
