MP3 to Stream adapter using p/n:000979010E & 3.5mm socket;
Hi
Just tried to fit above using to very good Youtube intall;
And the very good instructions on this forum.
and a 3.5mm phono socket.
Only to discover there is no plastic holder to support the wire set (p/n:000979010E) so I stopped fitting this as I am concerned that the conection might free themselves from the back of the Stream and cause a short.
Does anyone know if I can get just the plastic holder & if I can do you know the part number?
thanks
Just solder the cables into position :)
Just pop it onto the pin, it'll be alrite.
I've got the wire to do this myself when it gets warmer.
