PCV valve test
Hello,
I have searched and find only how to remove the valve and etc. but I can`t seem to find any info on how to test the pcv valve if it`s working properly or not. When I do the boost test, air is exiting from the pcv valve, is this normal?
Should air be able to pass in direction -> Y breather pipe -> pcv valve -> TIP if that side is pressurized? Should the valve be closed?
Best regards
