Heavy Braking
Hi, Just got my Yeti SE Greenline today and loving it.
Couple of questions -
1. In the active section of the Skoda Yeti brochure it mentions
Activation of warning lights during heavy braking - lets the car behind know of a possible hazard.
Does this mean under heavy braking the Hazard lights will activate?
2. Can the Sunglass holder be fitted after delivery, does anyone know the part code, or if a Sunglass holder from Fabia/Octavia etc will also fit?
1. Yes; that's the way I read it although yet to try it out or have the situation to use it. ;)
This is becoming a widely used feature and is fitted to FIAT 500s (I have experienced this) amongst others.
2. Yes; I believe the sunglasses holder can be retro fitted; not sure about part number though.
When I did the changes to my car via the VCDS we saw a few options for these flashing lights. Including one to disable it from, or was it enable it ? for the trailer you might be towing.
As to the sunglass holder it should be a very easy swap yes. Just need that part number.
I'm still getting used to the part system but the part number as far as I can tell is 1K0868837E then I think the trim code for the grey colour is Y20.
Hope this helps, I have no idea how much it costs I couldn't figure out how to find that out.
