Brake Calliper Mounting Problem
Morning All
After removing my front calliper mounting to fit new brake disks the threads of the two big bolts which connect the calliper to the hub have been stripped.
Has anyone had this problem? Any advice on what to do now?
Can they be helicoiled?
Any help much appreciated.
Id buy a new carrier and bolts if i was you as there 2 quiet important bolts and threads
New bearing carrier and wheel bearing.
Arnt the threads in the brake caliper carrier and it bolts through the hub
