alloy wheel info required
im looking into buying a set of alloy wheels for my mk1 superb
i think im going to go for 18" wheels, but i would like to ask, that is if anyone has the knowledge..
what is the max wheel width i can use? also what offset?
im wanting the wheels to sit almost flush with the arches/just slightly tucked in.
any help on this much appreciated :thumbup:
bump! anyone.
Firstly I think a mod should maybe move this to the Superb MK1 section as you may get more response there, I know a little about wheels fitment to the Superb MK1 as I own one myself.......... ;)
So the wheels specs for the Superb are as follows:
PCD = 5 x 112
Offset = 35 to 45
Centre Bore = 57.1
Worth reading the following links to help you out with fitting different wheels with offsets:
http://www.1010tires.com/WheelOffsetCalculator.asp
http://www.kouki.co.uk/utilities/visual-tyre-size-calculator
http://www.willtheyfit.com/index.php?width=215&aspect=35&diameter=19&wheelwidth=8.5&offset=38&width2=215&aspect2=40&diameter2=18&wheelwidth2=8.5&offset2=52&Submit=Submit
I run two sets of wheels on my Superb, I sold the orignal 17" Solids and now run 18" Audi Fat Five's - 8.5J all Round 215/40/18 (Running 20mm Eibach Spacers all round):
As my second set I run the following 19†ASA AR1’s with Polished Lips – 8.5J Front’s 215//35/19, 9.5J Rear’s 235/35/19 (Running 15mm Eibach Spacers up front):
thanks for the info :thumbup:
your car looks the business :thumbup:
i like the look of them audi flat fives.
Thanks, approaching 200k but she is still going strong........ :thumbup:
would the following wheels fit the superb -
5x 112 pcd.
19x 10 rears et20
19x 8.5 fronts et20
thanks
5x 112 pcd.
19x 10 rears et20
19x 8.5 fronts et20
thanks
Did you not read any of the links I posted above.......... :(
I assume that these are off another marque, maybe something like Mercedes maybe? The PCD is OK but would suggest the centre bore may be 66.6 so you would need spiggot rings, the ET is your problem but the link I gave above gives you everything you need to know if you plug the numbers in.......... :yes:
The lower the ET means that the wheel will stick out more and the width may well cause you problems.
The higher the ET means the more the wheel will sit inside the wheel arch......... :thumbup:
Not sure how they will look on the car and I would be careful if you ran 10J wheels on the rear as they may not fit............ :doh:
As a side note, I am selling on my 19's as pictured above........ :thumbup:
Pretty sure the Alphards only come in 18's as a maximum.......... :yes:
If you can get them big enough, these might work.
http://www.google.co...iw=1024&bih=629
so in 19s what MAX width would you suggest? and also what offset? im seriously crap at things like this.
All the info is in those links above mate........ :thumbup:
