Warning lights gone mad...
I was driving home last night, and all of a sudden I got a bulb warning light that my front drl was out. Checked it, and it was fine.
Couple of minutes later another warning 'check coolant'. When I got home, I switched the car off, waited Minute or so, switched the ignition on and it seemed fine.
Car Was serviced 5k ago so should not need coolant yet.
Was this just a blip??
Possibly, although I would be tempted to explain the symptoms to your dealer and ask them to read the car for any registered fault codes under warranty.
not another trip to the dealer!!
Will see how it is over the weekend, and if it happens again I will. just very time consuming to go there (about 30 minutes each way)
thanks for the response.
Typical Peugeots, electrics always play up on them :smirk::giggle:
You might want to update your car details....
