Pastyboy Retro Badges - Full set of 6
Due to a clerical error I have a full set of my retro badges without a home.
80mm diameter bonnet/boot badge x 2
55mm alloy wheels centre x 4
Correct sizing for mk1 Fabia or Octavia
Retro design - black on silver
As modelled here:
Ideal for any car; but even better on a silver or black one.
£40
I could well be interested, how easy are the standard ones to remove and these to fit?
As far as i know it's simples (i must of sold 100 sets and no-one has toldme they've had problems)
Original bonnet/boot ones are only held on with foam adhesive padding which with a bit of heat (hair dryer) comes loose and the badges pop off. alternatively fishing wire can be used to saw behind the badge and seperate badge from glue.
The mine just stick in their place (i think some have even stuck them over the top of the OEM badge)
Wheel badges are the same - pop out the centre caps. put in hot water for a few minutes. use a screw driver to seperate oem badge from centre cap. stick mine in their place.
easy peasy :thumbup:
I'd like to take these, if you PM me the details ill sort out payment. Thanks
Bugger too late. If you do anymore would take a set of front and rear for a mk1 octy.
Tim
PM sent :thumbup:
Tim
Tim while these are sold I can still get them made to order so if you want some just drop me a PM :thumbup:
SOLD to Morrellski :thumbup:
Guest
