washer pump replacement
Now ive upgraded to a 5.5L tank the pump is leaking the washer fluid overnight :wall:
Does anyone know which aftermarket windscreen washer pump is a direct fit?
The cheaper aftermarket ones ive seen only seem to have a single outlet (mine has a 2nd outlet for the rear screen) and I dont see the need to spend £30+ for a genuine Skoda part.
ta for any help
Edited by 2276
chances are you've accidently pushed the rubber gromit into the bottle that fits onto the pump bit that's pushed into the washer bottle. Strip it apart and take a look. I bet it's floating around in the washer bottle.
lol I did that a few weeks ago - ive taken the pumps motor apart and its leaking through its rubber seal, so its a new part needed
Scrap yard for a replacement pump (if you can find a suitable Octy/donor vehicle).
we sell loads and carry 7 in stock the problem with a scrapyard one is how long will it last????
