Setting cruise control
Hi all . I'm going to get my cruise control turned on with the VAG Friday . His alittle unsure how to do it as it be his first . I got my cruise control from skoda and told him in the manual that came with it tells you how to turn it on by entering the code and that's it .
Is it as simple as this or is it more in depth ? Thanks
Very simple to do, fitted mine and coded it last week. I have a DIY guide that i will being loaded up over next few days.
Look at page one of the PDF link below
http://vwgolfr32.co.uk/ccs.pdf
Just select the Engine controller 01
Select Login (11)
Enter Password 11463
select "do it"
job done
I take it that you have had the Cruise control kit fitted already..
piece of piddle mate, dave did mine on the other ECU.
took 30 secons if that, takes longet to start VCDS lol
:thumbup:
You can also check the cruise, brake and clutch switches are working at MB 66.2 and 66.4
Yes me and my dad ( wolfinsheepsclothing) fitted it the other week . Told him I've got the code just wanted to know if it was that simple . Happy days :)
Hi all . I went and got my cruise control programmed in today . Like you all said took no more then 30 seconds ! . It's very good , it remembers what speed your at when you have to brake , you can speed up without touching the pedal just by holding the button in . When its on feels like your a passenger feels weird lol
Got there in the end then :thumbup:
well done.
bazaa
