retrofit light assistance
PLEASE CAN ANYBODY HELP B)
YESTERDAY I TOOK OUR 2011 FACELIFT 1.4TSI DSG OCTAVIA ELEGANCE TO OUR LOCAL DEALER TO HAVE A NEW BOLERO RADIO FITTED UNDER WARRENTY, WHILE THERE I ENQUIRED ABOUT HAVING LIGHT ASSISTANCE FITTED, I WAS TOLD THIS GOOD NOT BE DONE AS IT IS ONLY A FACTORY OPTION AND THE REQUIRED WIREING LOOM WOULD BE MISSING, ON OUR CAR WE HAVE FULL MAXI-DOT RAIN SENSOR ON MIRROR FULL MFSW + PADDLES, SO IS THE DEALER RIGHT?
  • 1 year later...
I just swapped the lightswitch on my octy facelift, and used vagcom.
It is retro-fittable as far as I am aware - you need the new light switch, a bit of coding with VCDS and maybe an extra wire running to the light switch, but don't quote me on that!
As above, 1 wire (but it may already be there) 1 light switch and then coded. The maxi dot can then control coming home, leaving home etc.
I did mine and the hardest bit was running the wire into the main box, bit of a pain because the main electrical box is under the steering column and it's tight in there.
Edited by vrs777
The Elegance should have the light sensor as well as the rain sensor. I did my pre-FL (switch and wire) and had it coded in VCDS. Didn't take long to do.
