vrs 1.8t hard to start from cold ?
hi there i am havin a problem with my car from cold its a 2003 octavia vrs k04 hybrid conversion , its only hard to start from cold and runs ok once started and warm , i have fitted a new oem coolant sensor no change i have used vag com and no codes and done a search on here and nothing so if you have any ideas that would be great
Air temp sensor in the trottle body maybe ? Do your revs go up and down and stalls ?
no problem with stalling mate just takes ages to start when from stone cold
Temp sensor has gone!
It's a little sensor that lives along the top hose from the radiator! I'll try and find a suitable pic!
£30 from Skoda, 30 second job!
Steve
Steve
i have changed the main cts for a new skoda green one or is there a diffrent one ?
Sorry, I misread your earlier post!!
Steve
is it poss to change this without needing a dealer ?
Do you mean to put It on the computer if so then no you don't need to . It's amatter of case of just changing it . I brought mine from the dealer . Cost about £13
You can check if it is the throttle coolant sensor with vagcom. If you look at Measuring block 004, it will show you what the air temp sensor, and in fact, the coolant sensor, are reading. Obvioulsy if one of them is showing a value which is miles out, change the relevant sensor.
i will have a look tommorrow
