Speaker Advice
Well i have 6 speakers in total
2x clarion rms 25w each
2x alpine rms 15w each
2x kicker rms 25w each
my head unit is jvc and says 4x50w...
so could i run the 6 speakers from this head unit?
cheers
cheers
Hmmmmmmm....your unit has 4 channels (front and rear drivers and passenger side...like most headunits) each one with a max output of 50w. What/where are your speakers going?? Are they bass, mids, or tweeters???? B)
Well i have 4 standard positions
And i was thinking of squeezing another 2 in somewhere
There mids i believe just 4" speakers
Not on a fabia btw
On my car I have 8 seperate speakers in total.....1 bass/mid (25w to 30w), and one tweeter (15w) per channel (4 channels)...so the max I am loading is 35w + 15w = 45w.......and head unit is a 4x50w output so as 45w is less than 50w I'm ok!!!
You can put the speakers where ever you want.....just remember that there are only 4 speaker inputs (rear passenger side, rear drivers side, front passenger side, front drivers side) and each one can only support a max of 50w!!! The head unit might also have an input for a "sub woofer" single channel signal output to an amplified sub (I know mine does).
I presume that the 25w are bass/mids.......one set in front door...one set in rear door......15w are tweeters...one set in dash top....might need a set of tweeters in the rear side fixed panels next to parcel shelf to shift sound stage better!!! What car is it in??? B)
