s3/tt coolant bottle cover
any got one of these fitted to their VRS? just curious to see one on an octy
near enough £80...think i'll give it a miss actually :giggle:
Edited by Flybikeslee
I had a look at those as was thinking about it. But again at that price i forgot it. I may go for a cam cover brussed steel. The one that curves over the coilpacks.
Got one on mine but as said if your buying from the stealer there pretty pricey,if you want to see a pic there's one in the link in my sig
:thumbup:
is there an extra bracket for it? i've looked on vagcat and by the looks of it there is :wonder:
Yes you buy the cover,bracket and a bolt if I remember right and the bracket mounts from the header tank screws,you could probably make a cover yourself a lot cheaper and be aware that in order for the screenwash bottle to line up with the hole you need the 5.5l washer bottle or if not do like I did and make a bracket to move the existing bottle across to line up with the hole
ah, cheers for the info dude, if i see one cheap enough i'll grab one, hide that evap canister and other crap :giggle:
