anyone in SHROPSHIRE with VCDS or VAG-com ?
anyone in SHROPSHIRE with VCDS or VAG-com ,,,... mine keeps crashing and need to get my installed cruise controll working
When you say crashing....
You need to be quite careful there if you think it's a computer hardware fault, as a crash at the point where it's trying to update a module's configuration could be particularly unpleasant.
Have you another laptop you could try your cable with? Or perhaps uninstall the software? As you probably know, the VCDS license actually lives on the cable, so you can install the VCDS software on any other PC and be working with that inside 5 mins.
I'm the wrong end of Cheshire from you I'm afraid.
Im installing it on my wife's laptop now
i dnt mind traveling to you if u can help.. if i cant get a solution today
iv checked wiring and im getting power right through to the ECU. so its just internal stuff now to re-check
Good luck :)
Yep, if you've got the correct coding to hand I don't mind taking a look, as it's been a good while since I worked on a Mk1 emoticon-0148-yes.gif
component reads : 1,91 R4 EDC G000SG 3**2
Extra : ****G41U******19*
Meas Blocks :
brake pedal on : brake pedal 011
cruise control 010001
cruise system 17.0
clutch oedal on : brake pedal 100
cruise control 100001
cruise system 17.0
Cruse button depressed : : brake pedal 011
cruise control 001001
cruise system 1.0
from this its telling me everythin is working then ?
Edited by Tim_davies-moss
are you certain that you have the wires correct into the multi plug behind the dash? double check those first as the no's on the block are hard to read,
are there any faults in the engine ecu?
a brake light or clutch switch fault will stop the cruise from working too.
