anyone local west midlands area could fit me induction ebay special and boost gauge
have a 2004 octavia vrs
sadly no good at all with cars
is there anyone local could fit me a induction kit ebay number 350473916646 and a boost gauge
message me with a price dont mind traveling upto 45mis ish
thanks
Edited by lee1972
I love the ad
"Adds up to 10 to 15 additional horsepower and up to 16 foot pounds of torque ! ( result might be vary )"
Cost £300 upwards to get 30bhp from a remap, but this CAI can add 15 for 38.99!! Get me two! lol.
Personally my friend, I would say give it ago yourself. I know you say you're not car literate but with these vag cars I personally believe it is worth learning how to do it yourself and with something like a CAI it is so easy to fit.
A million and one guides on here (search : bowders1)
The only thing you have to be careful of is the MAF because it is delicate.
Quick how to...
Remove the front passenger side grille located at the bottom of the bumper( put two screw drivers in the bottom and pull out)
You will see a solid plastic form in your way, you will need to cut that out.
If you want to keep the original diamond grille, you will have to scratch away the back of it until you cut through to make air holes. I used an angle grinder. If you don't want them then you can just buy grille inserts from miltek. I personally think mesh is tacky but its your choice at the end of the day.
Look in the engine bay for the airbox (above the battery box) unplug the MAF's sensor and then with a set of pliers pull back the clamp and detach from the top of the airbox.
Unplug the Secondary air pump pipe, located on the side of the airbox, engine side.
Take the lid of the airbox off, out with the filter, unbolt the bottom on the box. 10mm's I believe.
Get the rubber pipeing of the kit and attach that to the MAF, same way it was attach to the top of the airbox
Get the main pipe and attach the filter to the longest end with the jubilee clip. Feed it down past the the battery box. Some people remove the bumper. but all you need to do is remove the light to make life easier. 10mm and pull it out.
Once in place attach the metal pipe to the rubber pipe with another jubilee
Using the smaller filter, attach that to the secondary air intake pipe. The hard plastic flexi pipe you took off the side of the airbox. Cable tie the pipe low down and away from the engine.
Job is done.
A good 2 hours work at the max.
thanks but would still be safer to pay someone to do it
i know i would mess something up somewhere
Let us know how it goes once fitted, I also had a look at that eBay jobbie...
contact me mate i will do it for you no probs , only in blackheath 5 mins from you we have got a meet on toys r us tonight if you want to pop down its rich i will pm you my mobile number drop me a text
Also willing to do it for you but i am over in Cannock. Can do it after work or weekend to suit you buddy?
No charge dude just for fun lol.
Thinking about it what boost gauge have you bought and what fitting to hold it?
Dave
sorry mate been held up all nite long story
is the meet every week?
