headlight setup for france/italy/germany
I'm after the instructions for setting up headlights for driving on the other side of the channel. I don't have cornering, maxidot or xenons. Is it just a case of moving some adjustments? Can I avoid sticking on reflectors?
cheers,
Stu
This is for the facelift but the process is near identical...
Undo the nylon securing nut on back of light cluster under the bonnet...
Push small black square tab and pull hook on side of light cluster to unlock and release unit forward...
Light cluster released...
Remove main larger rubber cap...
Now the 2 metal levers are visible they appear to be on a bezel and moving one also moves the other simply move to opposite position...
Reassemble in reverse order and job done. :thumbup:
Final result.
Final result.
I recognise that pen and that car and that work top very similar to my guide :o
