VRS- 6th gear low revs only
Hi.My 6th gear only revs to 3000 rpm or just over and won't go any further.Is this normal.My 4th,5th etc goes to 5000 odd
your 6th gear will rev that far...... if you go fast enough
It stays at that rev range and won't go any faster either.Gets there quick but just stays their.
It's a well kept car,no faults that I know of and 80k fsh.Could it be something blocked
It's just the STD car running out of steam I'm afraid.
ok cheers mate.I was expecting it to have a better top end than my old 90bhp golf tdi at least :(
i would suggest something is not right, was there an incline involved?
I would expect you to be able to go faster than approx 100 mph in your fabia Vrs
mine used to pull past 3k with ease in top gear
The car should keep pulling to an indicated 140 ish where permitted in 6th. Something is definitely wrong if its stopping at 3000 rpm.
It's all good.Form what I've looked up that is the nature of the diesel.They don't rev high in 6th.It's a 130bhp 128mph car afterall not a 250bhp 160 car :yes: I'm happy
Nope. There's definitely something wrong with it. Were you doing 128mph at 3000rpm? Unlikely so there's something wrong with it.
Edited by Dave_G
Hummm, if your going up a big hill, or into a headwind then i`d say its ok, but if you were on a flat road, flat out for a while and wouldnt go any further then maybe there is an issue.
Matt
According to my source mph/1000rpm figures are as follows for a later car running on standard wheels:
4th = 21.88; 5th = 27.15; 6th = 32.51
So 5000rpm in 4th = 109.4mph; 5000rpm in 5th = 135.75mph; and 3000rpm in 6th = 97.53
I'm pretty sure now that it would get near 4000 rpm in 6th given a long enough road.It just doesn't go round the revs quickly,which is normal looking at others on Utube :thumbup:
To the OP - what happens if you change up to 6th when going in 5th at 5,000rpm? Does it slow down all the way to 3,000rpm?
drj
From max revs in 5th then change to 6th it goes slightly faster but takes a long time.
I understand the car does a max 128,as I said it's no Ferrari
Plus on the earlier gearboxes the car will go quicker in 5th iirc
Matt
