decat pipe fitting
anyone know if i decat pipe for a golf 1.8t mk4
will fit a octavia vrs 1.8t
or will it be to short
Yes it will fit as they are the same pipes. Both cars share the same engine hook up points and floor pan.
Only difference is the back box
I take it the same goes for the A3 and Leon?
If i bought a golf exhaust are all the hanger points the same?
Think they would fit till the mid section, after that the octy's different
Correct you will be ok up to the rear beam hanger. The back box on the Octy is longer and therefore the rear hanger is in slightly different place.
thanks guys didnt fit lol
the bore was to big on the cat pipe
Boy you are opeining lots of threads on this topic.
Actually they do fit just because your garage can't handle a bit of messing about or can not seem to work out how to get it fitting(where most garages I know would treat it as a walk in the park)does not mean it won't fit. If you are expecting them to fit a std cat back system they won't without the previous mentioned actions.
However and i can appreciate where you are coming from on a good note, this is the add you bought right.
http://www.ebay.co.uk/itm/350485423857?ru=http%3A%2F%2Fwww.ebay.co.uk%3A80%2Fsch%2Fi.html%3F_from%3DR40%26_trksid%3Dp5197.m570.l1313%26_nkw%3D350485423857%26_sacat%3DSee-All-Categories%26_fvi%3D1&_rdc=1
These are the statements he makes.
- Manufactured from T304 grade polished stainless steel,
- CNC machine flanges for strong solid support,
- Professionally made,
- This cat by-pass pipe will improve throttle response and increase power by up to 10BHP by letting the exhaust system to breath easier,
- Fantastic high quality stainless steel that we guarantee you will not be dissapointed with,
- Direct bolt on replacement for your original cat,
- No modification needed,
- Gasket not included,
- 100% Brand new in the box,
- Warning light may come on due to removing the cat (needs resetting),
**Sold for off road use only, will not pass an MOT**
So as he has "not" implied modifications may be needed and that he claims a direct fit, you should get your money back, as that decat would also not directly fit all those other cars either certainly without a sleeve(that he has not stated or supplied) :thumbup:
yeah thats the add hes now saying its for the 1.8t 20v but will not fit the vrs ( nothing like this on the listing though )
the only place i could get it fitted was just a normal tyre and exhaust centre
who normaly dont do them but had a go as he knows me as a regular
tried around 8 other places including a couple who makes there own exhausts and pipes wouldnt do it as they only fit there own items
and none of the others would do it neither
my own fault realy just read the listing and thought it would fit right on
Edited by lee1972
yeah thats the add
This is the one I bought....
http://www.ebay.co.uk/itm/SEAT-LEON-20V-1-8T-STAINLESS-EXHAUST-DECAT-DOWN-PIPE-/140547954201?_trksid=p4340.m263&_trkparms=algo%3DDLSL%252BSIC%26its%3DI%26itu%3DUCI%252BIA%252BUA%252BFICS%252BUFI%252BDDSIC%26otn%3D8%26pmod%3D350485423857%252B350485423857%26po%3D%26ps%3D63%26clkid%3D2507540609770923764
Same as yours.
But the add lists this:
Features:
- Our products are 100 % Brand New and Boxed.
- Mandrel Bent T-304 Stainless Steel.
- This exhaust downpipe's mirror polished, 3" all the way.
- Improve throttle response & Housepower by 7-15 BHP
- Gaskets & bolts are included as you can see.
- You will get exactly which the above pictures shown.
- Professional fitting recommended.
- Supplier fitting, please contact 0121 3594594 for further information.
So this guys was being clear about potential messing about to fit the exhaust and even recomending a fitter.
Shame your add was not clear...So not really your fault not a completely clear add.
Same as yours.
Features:
didnt see that at the time only 20 mins away to
and by the sound of the add they fit to
have to try and get money back on this first
still £30 down though and still have to pay for the time the garage spent on it
