Electric problem
Hello,
my problem started when my radio goes off while i was driving, but then i realize that when i stoped on a red light the radio comes on again.
Then i see that radio turn off when i accelerate and turn on when my felicia was running at ralenti (bellow 1500rpm's).
I went to a battery guy that told me there was a problem in a diode from the alternator, and the alternator was overcharging the battery.
Maybe he is right, also because i notice a bad smell inside my car.
Ok, not a big deal, but then i lost my front medium lights, a day after lost the front fog lights, and the last thing was the electric windows.
I notice that the windows goes down, but do not go up.
So now i have my felicia inside the garage with both windows open, and they dont close.
I've checked the fuses and they look ok, cai it be a relay ?
Can i solve this easly , is this a common problem , give me some ideas or feedback of what you think about this problem.
Thanks.
It does sound like the alternator voltage regulator is broken
Seconded. It's a very common problem, and the diode pack (also known as the regulator or control box) on the Felicia can be changed separately from the alternator itself.
Meanwhile, you are over-volting all your electrical and electronic equipment, causing it to fail. Get the regulator changed ASAP!!:dull:
