decat shape ok or damaged
just had this come today from ebay
brand new
is the dent meant to be there or is it damaged
thought i would check before getting it fitted
That's definitely damaged.
ment to be ther
If it wasnt there mate you wouldnt be able to get the Nut on to tighten it due to the angle and size pipe.
which one was it? the one that finished at 0930 ish in the morning? I was after it, went for £41 due to time it ended but I fell asleep, DOH
one in the morning from 2fast2cool2 went for over 90 lol that same evening.
Its fine tho mate.
Its fine tho mate.
yeah that was the one £90.07 i think i got it for
finished at 7.50pm or 8.50pm i think
ok thx can get it fitted now
You must be joking?
Thats damaged. Why fit something damaged to your car? Its brand new, send it back?!
ment to be ther
Sorry Billy not meant to be there, that is definatley damaged.
I have the same 2 piece decat (although they are all made be TOYOSPORTS) i think.
Yes the bolts tightening is a little difficult and you need to equally tighten them down to make life easier. I have pics and a DIY install if folks need it.
But that dent is not meant to be there.
Return that exhaust back.... :thumbup:
May I see this?
Marc
have emailed the seller no reply yet
as few other sellers on ebay and they say not meant to be there
hard to think could have got damaged in transit would have needed to be a good whack
different points on this so still have no idea lol
thanks guys
well its real simple, are you happy that you exchanged your hard earned for a piece of bent pipe?
for me its a no brainer, maybe I'm just weird?
Mine doesn't look like that? Looks damaged to me.
the one I had was just the same mate
its how they are!
have you tried denting it? they are not easy to dent not like that.
my pic of it is taken from the other side so cant prove to you that the one on the 51 car wasjust the same.
its there to give easier access to the nut.
its how they are!
I see what you are saying Billy, as having fitted one just like it(without the dent) is a right pain as getting the nut on the turbo manifold is very fiddly but not impossible.
That size dent to me though would interfear with exhaust flow and seem quite a dent just to let more access to the turbo stud/nut on manifold. Could it be yours was dented too?? bit coincidental I agree...
few pics of mine
looking at the pic makes it worse tho, its not really a dent, its been pressed in by a chisel like end 1-2" wide. and that one is in the same location to mine. Its not in that far and might upset flow ever so slightly but tbh still plenty big enough as its 3".
Sertain sellers must of put it in to make it easier as buyers might of complained they couldnt get the nut on?
The dent is on the other side:
Isnt it wierd tho that both look pritty much identical?
Your one Mark just has a Toyosport plaque spotted on. Prob all made by same person just different sellers slightly adjust the item to suite?
bil
it is made by Toyosports as was on the box
have emailed the seller no response yet
had few replies from other sellers selling selling them and they have said shouldnt be any dent
will the dent effect the item or just cosmetic ?
if it wont will just get it fitted
have attached new pic of the inside
that's been deliberately heated up and hit with some sort of chisel. it makes sense that the seller did that because of previous buyers complaints of hardness of fitting, but still it doesn't make it right to sell something with a massive dink in it and not make it clear when purchasing.
don't know about you guys, 3 inch pipe or not, I wouldn't want a dint in my pipe, I'd make it fit without.
maybe the seller who i got it from does this btefore sending them out then to make it easier to fit
although nothing was said in the listing waiting for a reply from them
at the least i will try and get some sort of refund
yeah does look like a chisel as you can clearly see the line
+1
That is what I did....
And I heat wrapped mine which made it even harder to fit. :giggle:
Intersting as mine is a TOYOSPORTS one with no dent??
go figure....
Why don't you call TOYOSPORTS on Tues and check whether some had this dent from new, and if not, whether they consider it to be an issue with flow or longevity?
This should also give you either a) peace of mind or B) the evidence to file a claim.
good luck
have been offered a partial refund of £25 by the seller
so guess its not meant to be there or the seller doesnt realy know
will it effect the use of the decat
if not will except the part refund as looks like some are sold like this
tis up to you mate, but Ide take it. I wouldnt say youll notice any difference really as its minor.
youll find they are getting them for 40 notes or so so they not too bothered. you might be the first to ask them?
personally Ide take it and fit it. but then I have seen other ones like it and had one on the car so thats why I thought it was normal but end of its up to you what you feel better with.
:thumbup:
