Air Con smells
So Ive had this prob since I bought the car. Only occurs when i first turn on my climate control. I have since had my aircon serviced/recharged but its still a cheese fest. any ideas?
You could try getting the pollen filter changed.
Ian
Ask your dealer to clean the air conditioning system
http://www.skoda.co.uk/GBR/owners/caring-for-your-car/air-condtioning/Pages/default.aspx
My previous car developed a musty smell from the air con. I had them clean run their cleaning system though it and that cured it , after trying an off the shelf product which only lasted a few weeks. Cost was £20 a couple of years back and only took 30-40 minutes while I waited.
Edited by squidgy
+1 for cleaning system. They usually use stuff that kills bacteria and fungus build-up that is often the cause of nasty niffs.
You can buy similar stuff to do it yourself; I did on SWMBO's car, but managed to get it all over the seat backs & headlining!
Check that the evaporator drain isn't blocked.
That "Parmesan" or "smelly feet" smell means that you have mold growing in there and that's not good for you.
Usually, off-the-shelf products only mask the smell. That's why the smell oftem returns. Commercial products contain chemicals that kill and prevent mold/mildew so go to an a/c specialist.
You have in the market a spray that helps this.
This happens because the AC is never/hardly used, It will go away if you start using more often the AC and drive with the window a bit down.
On another hand the cheese, I can bring the Oporto wine or any other type of wine in Oporto area. ( wine from DOURO)
Edited by alberg
