starter motor
will a 1600cc petrol starter motor fit a 1900 diesel, thanks,
Yes but it won't last long because the diesel engine has a much higher compression, the diesel uses a 1kw motor with a reduction gear setup.. However if you were stuck at the side of the road and it's all you could lay your hands on it would get you home.
thanks,
