256mm brake setup + 312MM setup!
I have for sale a set of rear brake calipers, from a Golf mkiv R32.
They WILL fit an Fabia VRS, however you will need to create some 6mm spacers, as per below to run them......
6mm plate can be bought from here, I reckon 200mm by 100mm will suffice, under a £10. Alu over steel, so it won't rust as bad.
The calipers themselves are very good, and spring back with very nice return, I've seen a set in the past which suffered with lack of spring return, thus catching pads on disc, and "mooing".
Obviosuly, they'll need a paint to match VRS green, so I'll supply 500ml of Hammerite, smooth green with the price :-)
I want £75, and I will post for £10
CLick here for £45 discs/pads that will fit above calipers
Actually, £65 will do!
Would there be intrest if I got the brackets made up?
Is the 65 quid including postage? And brackets? Cheers.
yeah i recon so mate
Also, for sale now:
312mm Fronts with near enough BRAND NEW mintex pads and EBC discs (10k left in them). - £180.
I'll be selling the rears, with brackets made to fit the carriers and generic pads (10k left in them) and EBC discs (Pretty worn to be fair, but new ones can be had for not much.) for £100, or £80 if you wanna make the brackets yourself!
so whats the price for it all mate and would this be the everything required to fit both the front and the rears?
matt
I'd sell all kit for £240, or £260 with brackets made up already.
I really can't be bothered to make up the adapters to fit the rears, as i don't have the workshop, or time to do it!
All you need to do is buy 6mm plate as shown in link above, go to an engineers with the carrier, and say "please match plate to carrier, two off please!"
Yup, discs front and rear, calipers front and rear and pas front and rear, ad I'll chuck in some hammerite smooth green so you can paint rear calipers :-).
All what's required is the 6mm plates to fit the rear calipers!
I'd prefer to sell them all together, as it's less hassle for me lol!
Oh, I'm based in sheffiled, derby and Solihull, so can sort out pickup/delivery, as I drear to think how much it'll cost to send this lot!
Offers?
Guest
