emmisions update
hi when i put ignition on i get emmisoin workshop + engine management light on but it runs ok got the guy i work with to scan again and he redset it i managed to get a quick look before he reset and saw this
signal to hi
po471
then i think it said sensoe G450
ANY IDEA GUYS MEANS NOTHING TO ME
Below is the list of sensors (prefix G) for the 1.9:
G28 Engine Speed Sensor
G40 Camshaft Position Sensor
G62 Engine Coolant Temperature Sensor
G70 Mass Air Flow Sensor
G71 Manifold Absolute Pressure Sensor
G72 Intake Air Temperature Sensor
G79 Throttle Position Sensor
G81 Fuel Temperature Sensor
G62 (engine coolant) is the most likely to fail and the engine will run normally with a failed sensor - it takes a scaled value from G81.
Find out which one it was - but if G62 has a black body, change it. Later versions are green.
rotodiesel.
