pioneer avic-x1/r
right now i have ordered my avic-x1r and now i have just been reading the manual and i just wanted some advice fromanyone who has fitted one of these. the speed pulse wire is it in the connector to the headunit ? where to mount the second unit etc etc
ta in advance :)
Hi If You Are Still Looking For The Speedpulse Wire Location It Will Be In The Power Iso Plug. The Loction In The Plug Is Normally The Pin Above The Release Button If You Are Still Having Problems Give Me A Shout And I Should Be Able To Find Out The Colour Of The Wire,as For A Loctaion To Put The Main Brain I Am Not Sure Have Not Fitted One To This Vehicle Yet But Make Sure It Is Sitting Straight Or Can Cause Problems Will Let You Know If I Find Out Any More Details.
i had an idea about fitting it in the secret location in the glovebox but dunno if i could ?
also i need a wire that goes live when the cars put in reverse ?? i know reversing light would but is there a wire upfront at all ?
I Find Running The Wire To The Reverse Signal Wire In The Boot The Easiest Solution
