Extra Guages - help
Needing a little help please, is anyone on here running a oil pressure (electric) and oil temp gauge please.
If so did you fit the sensors to the spare port on the filter housing and what tee piece / adaptor did you use.
Many thanks
I am yes using a 42 Draft Designs adapter. On mobile so I can't post a direct link but look at my website under miscellaneous. Link below in my signature.
Well just to update / close this I never fitted them in the end the spare plug on the filter housing was seized solid so I left it alone in case I broke / sheared it off.
