Dashboard query
Hello all,
Just a quick query, on my VRS the passengers side of the dashboard doesnt have any plastic trim at the lowest point, between where the dashboard area meets the footwell. There is no plastic trim below the bottom of the glovebox, all that is there is a sheet of foam padding.
I dont think this is meant to be the case, just wanted to check and see if anyone knows a part number so i can replace the missing plastic trim.
There is nothing there on mine - mine is a different spec, although I have not seen any others with trim on that part of the dash.
I have had my vRS from new, and all it has is the foam. It's definitely the standard part.
Cheers chaps, at least that means i dont have to spend any money on it :)!
