Double DIN stereo
Hi,
I have just fitted a AVH3300BT to replace the stream head unit. Used a Connect2 kit from Dynamic Sounds and everything fitted and the majority of function are working. Just 1 thing left, I need to tap into the handbrake switch to enable some of the units function, but I'm a bit worried about how best to do that.
Anybody else fitted this unit or had to tap into the handswitch? Any advice or suggestion would be greatfully received.
I've read before that you can just take the head units handbrake feed straight to earth, then you can use all of the functions all of the time. The handbrake feed is there to stop you from watching films/TV while you're driving.
