New headlight cannot adjust the dipped up enough
Help needed
The led DRL on my right drivers side head light failed as the headlight sprung a leak at the seam between lense and plastic case next to the wing
Bought new skoda headlight from skoda dealer and fitted it but the dipped beam is just far to low
Odd but the nylon adjuster looked as though some tool had already been on it so I was suspicious
The main beam was ok with a tweak to its adjuster which was in perfect order
I have rotated the dipped adjuster until i feel resistance. ( anti clockwise was lifting beam seemed odd direction as main was clockwise to lift ?) but it dipped beam still pointing down onto road and far lower than than it should be
2016 Fabia with the dome lense over the dipped beam bulb
