Steel Wheel Sizes
Hi guys just a quick question about wheel size. I am looking at some steel wheels on eBay and thought I best double check they are the right size for my octy they are 5 x 112 with a 42 offset and 6.5 by 16 inch. Any help or advise greatly appreciated
Thankyou
5x112 is correct and obviously 16" is okay too. For the ofset I suggest you take a look at the back (Alloys - front for steels) of one of your own wheels: The offset is stamped there.
Thankyou
They should be fine. ET of the 18" vRS wheel is 51 and the wheel is 7.5" wide. At that width and offset those steels will give you increased inner clearance of 22mm and the outer edge will be only 4mm further inside the arch.
