Geo settings
I am just wondering is the any way of dialling in some negative camber to my mk 1 octy ? On my civic I run quite an aggressive geo set up and it really handles well. The octy is ok but I really feel a good geo will make a huge difference.
I reckon I may be able to get a little bit of adjustment at the front but what about the rear? Also has any body tried running toe out at the front or do people just run oem geo
I don't think you can adjust the front camber much on the VRS, you'd have to fit the Audi S3/TT wishbones which allow more camber adjustment. There's no adjustment at the rear either (although there is on the 4x4 models IIRC as they have independent rear suspension).
I think mine has TT wishbones ? I no u can get adjustment on the bottom of the ball joint. I'm wondering about the toe out-in really. Also can I shim the rear to get a little neg camber
You can get adjustable top mounts for the mk4 golf which might fit but are pretty expensive and you can buy camber shims for the rear which are fairly cheap.
Camber shims sound like a good idea to me. Where from though ? Any idea
I've seen them on eBay before but they were when g werkes were on the go, think regal do them too but not looked for a good while to be honest
regal do them 0.5 1 or 1.5
are your wishbones casth then??? and did they do the hubs aswell for it to sit properly??
thank for help buddy
thanks buddy. And my wishbones are just plain old skoda ones :-) I thought I saw in the service history and lower arms. I did but it was for both sets of bushes 1 superpro 1 TT solid ones. I jacked her up after work and there just normal black metal arms lol my bad :-)
Found these on the bay 270601809216 will they fit ?? Surely there all pretty much the same
Yep they will but no point doing it unless you van alter the front wich you can't
mmm
whats this about shims?
I would like to do it on the rear beam to make the rears more neutral rather than toe in. also sort the camber out too so it doesnt wear the inside as bad as it does.
what does it entail to do it?
billy
to OP
get the Cast wishbones and TT/LCR hubs mate, that with the coilovers set down improves the handling.
there's these golf ones but don't know if the fit the octy
top mounts
Yes those top mounts fit
Rear Shims ordered
have you got a link clive?
I am looking at getting the 1 deg kit off ebay: http://www.ebay.co.uk/itm/270601814411?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Or the 0.5 kit, just need to pm Peter at ABC in Leeds to see what he thinks. I am happy that tis will sort the camber out but I want to get rid of the TOE in. I want a more 0 Toe rather than the L +3.9mm R +4.4mm
What ever ABC did when I went up last year it really made it feel better and less drone from the rear. he totally repositioned the beam.
mmmm
