Brake pad sizes
Any one out there in Skoda land who knows the size of the front pads and the rear pad at all??
Like wise with the size of the discs front & rear??
I emailed my brake supplyer but he needs the info before he can give me a price!!
Ta!! :)
and we need info on your car too!
Opppsss!! Was kind of in a rush!! :
Any way it's the mk2. 08 plate Tdi elegance tdi pd8v
8v?
Didn't realise that went in the octy II, most of the 2.0 TDI were 16v in the octy weren't they?
If you've got the same as the other octy II 2.0 TDI, then your front disc size will be 288mm.
Edited by cheezemonkhai
8v?
The BMM 2.0 PD as fitted to Octavia II inc Scout, Superb II etc is a 2.0 8v with DPF.
could also be 1.9tdi
Why would you need the size of the pads?. Normaly you just give the year, engine, spec or the number plate for the info.
strange request mate popping your reg into eurocarparts usually does it anyway
Front pads 54.7mm in height by 146mm in width
Rear pads 56.6mm in height by 105.5mm in width
Discs front are 288mm, Rears are 260mm.
Part number if its the 1.9 tdi, 1K0698151
